Einleitung
The unthinkable has happened. Your AGD4675YQ3 Admiral Dryer won't turn! The wet clothes are starting to stink and every company you call says the earliest they can get someone out there is 3 days away. Not to worry friends, the dryer is a much simpler machine than you might think. The most likely culprit is your dryer belt has fallen off its axel or snapped. With this guide, you will be back to finishing laundry day in no time. Bonus: You will also have newfound mechanical knowledge to brag to your friends about!
Was du brauchst
While keeping to the right corner, slip the butter knife in the slit above the dryer door.
Pry up with moderate force and the clip holding the lid will pop up.
Repeat on the left side.
Remove the 18.4 mm hex cap screws on the left and right side with the 8 mm socket wrench.
Remove the clips underneath the screws on the left and right side.
Using your thumb to hold the drum in place, pull the front panel of the dryer away from the drum.
Set the front panel to the side.
Grip the pulley bar and squeeze to push the pulley away from the drum.
Pull the belt off of the gear.
Form a loop with the belt and pull the loop under the pulley.
Squeeze the pulley bar and place the loop around the gear.
Rotate the drum counter clockwise and ensure the belt is covering the drum groove all the way around.
