Einleitung
Want to replace a Aerogarden Air Pump?
Einführungsvideo
Peel back the footpads at the bottom.
Unscrew the eight screws on the bottom to remove the base
Cut the wires as close to the pump as possible, to preserve their length. The wire connections are covered with glue
Strip the plastic from about 1/8 inch of the wire ends.
On the circuit board, note which wire is positive, and which wire is negative.
Connect the wires to the new pump and solder them in or affix them with heat shrink tubing for wires. Well, the solder should be covered with the heat shrink tubing, as well, since it is a potentially wet environment.
