Einleitung
Just taking apart my Aether Cone!
  1. It is held on with some double sided adhesive tape, just peel it back carefully from a corner Then remove all the screws shown in the picture Then remove all the screws shown in the picture
    • It is held on with some double sided adhesive tape, just peel it back carefully from a corner
    • Then remove all the screws shown in the picture
  2. Next remove the small circuit board on the end of the silver ribbon cable, it is held on with some more double sided adhesive Then remove the two allen head bolts hidden inside the case that hold the outer casing to the mid frame. Then remove the two allen head bolts hidden inside the case that hold the outer casing to the mid frame.
    • Next remove the small circuit board on the end of the silver ribbon cable, it is held on with some more double sided adhesive
    • Then remove the two allen head bolts hidden inside the case that hold the outer casing to the mid frame.
  3. Remove the ribbon cable and the connector holding the case to the mid frame Remove the ribbon cable and the connector holding the case to the mid frame Remove the ribbon cable and the connector holding the case to the mid frame
    • Remove the ribbon cable and the connector holding the case to the mid frame
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. undo the screws that hold the metal bracket in place and then disconnect the battery. The battery can then be gently pulled off the mid frame as it is held on by double sided adhesive foam tape. The battery is a 7.2v 5200mah battery consisting of 4 18650 cells.
    • undo the screws that hold the metal bracket in place and then disconnect the battery.
    • The battery can then be gently pulled off the mid frame as it is held on by double sided adhesive foam tape.
    • The battery is a 7.2v 5200mah battery consisting of 4 18650 cells.
  6. Remove the connectors plugged into the main circuit board Remove the connectors plugged into the main circuit board
    • Remove the connectors plugged into the main circuit board
  7. remove the screws and the main circuit board can be taken off the mid frame. Hopefully the photos can help with identifying the chips Hopefully the photos can help with identifying the chips
    • remove the screws and the main circuit board can be taken off the mid frame.
    • Hopefully the photos can help with identifying the chips
  8. remove all the long screws around the mid frame The midframe can then be lifted off
    • remove all the long screws around the mid frame
    • The midframe can then be lifted off
  9. this then reveals the two tweeters and the 3 inch driver which provides the excellent sound quality. this then reveals the two tweeters and the 3 inch driver which provides the excellent sound quality.
    • this then reveals the two tweeters and the 3 inch driver which provides the excellent sound quality.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nick Charlton
187 Reputation
1 Anleitung geschrieben
it would be great to get access to the firmware to enable the microphone and make it work as an assistant via Google API or Alexa API
peteandmika - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 313
