Einleitung
Use this guide to remove the head of an Afridev pump. Then follow the instructions in reverse order to install a replacement head.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Assemble the required tools, including the Afridev tool and crescent wrenches.
Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
Loosen the bolt on front of the face plate with the Afridev tool.
Remove the plate from the pump by lifting it straight up.
Fast fertig!
Abschluss
