Einleitung
Follow this guide to replace the casing of the Afridev pump, or to remove it for further repairs.
Ersatzteile
Keine Ersatzteile angegeben.
Assemble the required tools, including the Afridev tool and crescent wrenches.
Perform a water test on the pump, by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
Loosen the bolt on front of the face plate with the Afridev tool.
Remove the plate from the pump by lifting it straight up.
Insert the T-handle into the top cylinder of the exposed pump rod.
Loosen the 2 bolts on either side of the head to remove the handle from the pump rod.
While one person lifts up on the T-handle, remove the bolt and connection pieces.
Grab firmly on the T-handle and lift the pump rod straight up.
Expose the first connection of the pump rod, and support the portion below the connection.
While holding the pump rod below the first connection tightly, lower the first portion of the rod to a horizontal position.
Unhook the first connection by pushing it out and down, then pulling it away from the rest of the rod.
Place one wrench on the top side of the top base of the tank spout.
Place another wrench on the underside of the bolt in order to get more leverage.
Pull the top wrench to the right, and the bottom wrench to the left.
Remove the loosened bolt from the pump.
Repeat this procedure for the 3 remaining bolts.
Ein weiterer Nutzer hat diese Anleitung absolviert.
