Zum Hauptinhalt wechseln
Afterglow Wireless PS3 Controller Battery Replacement
Was du brauchst
  1. Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Afterglow Wireless PS3 Controller Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Frag FixBot
    Kommentar hinzufügen
  2. Afterglow Wireless PS3 Controller Battery Replacement, Battery: Schritt 2, Bild 1 von 1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Frag FixBot
  3. Afterglow Wireless PS3 Controller Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the soldering tool to heat the solder connecting the battery wires to the motherboard.
    • The soldering gun will loosen the bonds of the solder allowing the wires to be detached. Use this guide for further details on how to solder.
    Frag FixBot
Abschluss
USF Tampa, Team S19-G5, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 72
Insgesamt: 4,141
