Einleitung
This guide will show the process of removing the back plate, vibration motors, and motherboard to access the buttons on the front of the controller.
Was du brauchst
Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
Lift up and remove the controller back plate.
Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
Jiggle both joy stick control mini-motherboards out of their holding place.
Set aside the mini-motherboards so you can access the main motherboard.
Unscrew the two 9mm Phillips #0 screws holding the motherboard to the controller front plate.
Pick up the controller front plate and carefully turn it over so that the buttons left in it will fall out.
5 weitere Personen haben diese Anleitung absolviert.
