Zum Hauptinhalt wechseln
Afterglow Wireless PS3 Controller Joystick Replacement
Was du brauchst
  1. Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: Schritt 1, Bild 1 von 2 Afterglow Wireless PS3 Controller Joystick  Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Frag FixBot
    Kommentar hinzufügen
  2. Afterglow Wireless PS3 Controller Joystick  Replacement, Joystick: Schritt 2, Bild 1 von 1
    • Carefully remove the battery by lifting it straight up from its place.
    • Keep in mind that the red and black battery wires are attached to the motherboard. Handle these with care.
    Frag FixBot
  3. Afterglow Wireless PS3 Controller Joystick  Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the four 9mm Phillips #0 screws that are attached to both joy stick control mini-motherboards. There are two screws for each mini-motherboard.
    Frag FixBot
  4. Afterglow Wireless PS3 Controller Joystick  Replacement: Schritt 4, Bild 1 von 2 Afterglow Wireless PS3 Controller Joystick  Replacement: Schritt 4, Bild 2 von 2
    • Jiggle both joy stick control mini-motherboards out of their holding place.
    Frag FixBot
  5. Afterglow Wireless PS3 Controller Joystick  Replacement: Schritt 5, Bild 1 von 3 Afterglow Wireless PS3 Controller Joystick  Replacement: Schritt 5, Bild 2 von 3 Afterglow Wireless PS3 Controller Joystick  Replacement: Schritt 5, Bild 3 von 3
    • Firmly grip the joystick housing with your forefingers by the yellow squares.
    • Use your other hand to get a grip on the black plastic joystick and pull directly away from the housing.
    • This will take some force to remove.
    • Try not to use the motherboard for leverage because it is delicate.
    Frag FixBot
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S19-G5, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 21
Letzte 30 Tage: 147
Insgesamt: 5,397
