Zum Hauptinhalt wechseln
Afterglow Wireless PS3 Controller Motherboard Replacement
Was du brauchst
  1. Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Afterglow Wireless PS3 Controller Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Lay the controller face down on a flat surface and remove the seven 9mm Phillips #0 screws on the back of the controller.
    • Lift up and remove the controller back plate.
    Frag FixBot
    Kommentar hinzufügen
  2. Afterglow Wireless PS3 Controller Motherboard Replacement, Motherboard: Schritt 2, Bild 1 von 1
    • Desolder the battery connection from the motherboard.
    • Use this guide for more information on soldering.
    Frag FixBot
  3. Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 3, Bild 1 von 2 Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the two 9mm Phillips #0 screws that secure the motherboard to the controller front plate.
    Frag FixBot
  4. Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 4, Bild 1 von 2 Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Detach the main motherboard fom the front pate by carefully pulling it off.
    • Be careful of the trigger buttons when pulling out the motherboard. The bottons have mini-motherboards secured in place on the front plate. Carefully pull these out.
    Frag FixBot
  5. Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 5, Bild 1 von 2 Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove two button padding from the back of motherboard.
    Frag FixBot
  6. Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 6, Bild 1 von 2 Afterglow Wireless PS3 Controller Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Desolder the four button connections from the motherboard.
    • Desolder the joy stick connections located on the front.
    Frag FixBot
Abschluss
USF Tampa, Team S19-G5, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G5, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G5
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 55
Insgesamt: 1,890
