Zum Hauptinhalt wechseln
Aiptek Pocket DVII 1.3M LCD Memory Ejecting Assembly Replacement
Was du brauchst
  1. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: Schritt 1, Bild 1 von 3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: Schritt 1, Bild 2 von 3 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement, Memory Ejecting Assembly: Schritt 1, Bild 3 von 3
    • Remove the battery cover.
    • Remove the batteries.
  2. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
  3. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 3, Bild 1 von 1
    • Remove the four screws from the back side.
  4. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 4, Bild 1 von 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 4, Bild 2 von 2
    • Remove the sticky black dot.
    • Remove the hidden screw.
  5. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 5, Bild 1 von 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 5, Bild 2 von 2
    • Remove the two screws from the top side of the device.
    • Remove the two screws from the bottom side of the device.
  6. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the rear cover.
    • Be careful not to lose the spring inside.
  7. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 7, Bild 1 von 1
    • Pull back the front cover so that you can dislodge the side cover.
  8. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 8, Bild 1 von 1
    • Unfold the device and be careful not to tear the black and red power supply wires.
  9. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the four screws from the motherboard.
  10. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 10, Bild 1 von 1
    • Take out the motherboard while disconnecting the flip screen's cable from underneath.
  11. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 11, Bild 1 von 1
    • Remove the side cover.
    • Flip the device and locate the ejecting assembly.
  12. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 12, Bild 1 von 1
    • Remove the grey button.
  13. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 13, Bild 1 von 1
    • Push the metal arm the button was on all the way up.
  14. Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 14, Bild 1 von 2 Aiptek Pocket DVII 1.3M LCD  Memory Ejecting Assembly Replacement: Schritt 14, Bild 2 von 2
    • Pop the main metal arm out of the other metal arm's socket.
    • Position the arm vertically like in the first picture. The arm should come off easily.
    • Replace the ejecting arm.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 6-4, Brown Winter 2015 Mitglied von USF Tampa, Team 6-4, Brown Winter 2015
USFT-BROWN-W15S6G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 116
