Was du brauchst
Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
Remove the two screws from the top side of the device.
Remove the two screws from the bottom side of the device.
Unfold the device and be careful not to tear the black and red power supply wires.
Take out the motherboard while disconnecting the flip screen's cable from underneath.
Pop the main metal arm out of the other metal arm's socket.
Position the arm vertically like in the first picture. The arm should come off easily.
Replace the ejecting arm.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
