Was du brauchst
Remove the sticky black dots.
Remove the three black 4mm screws from the flip screen. Use a Phillips head screw driver.
With the cover off, push the brown locking mechanism up, so the picture cable can be remove.
As in step 5, push up the brown locking mechanism of the remaining cable.
Unplug the picture cable.
Turn the circuit board over and with a soldering gun remove the two wires on each end.
With the wires no longer holding the circuit board and screen together, remove and replace the broken screen.
