Was du brauchst
Unscrew the three 4mm screws from the battery side of the device. Use a Phillips screw driver.
Remove the two screws from the top side of the device.
Remove the two screws from the bottom side of the device.
Unfold the device and be careful not to tear the black and red power supply wires.
Take out the motherboard while disconnecting the flip screen's cable from underneath.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
