Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The barrel is the orange piece into which you insert the darts.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together. Remove grey slider from the main body of the blaster. Remove grey slider from the main body of the blaster.
    • Using a screwdriver, remove the two 11.6 mm phillips 00 screws holding the grey slider together.
    • Remove grey slider from the main body of the blaster.
  2. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together. Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
    • Using a screwdriver, remove the six 9 mm phillips 00 screws holding the main body together.
  3. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed. Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
    • Using the plastic opening tools, carefully take apart the main case of the blaster to leave the inside exposed.
  4. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin. Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
    • Remove the trigger, lifting from the bottom and pulling it out from under the metal pin.
  5. Lift the barrel, pulling it out from under the black trigger catch Lift the barrel, pulling it out from under the black trigger catch Lift the barrel, pulling it out from under the black trigger catch
    • Lift the barrel, pulling it out from under the black trigger catch
Abschluss
Joshua Taylor
112 Reputation
1 Anleitung geschrieben
USF Tampa, Team 3-1, Brown Fall 2014 Mitglied von USF Tampa, Team 3-1, Brown Fall 2014
USFT-BROWN-F14S3G1
3 Mitglieder
5 Anleitungen geschrieben
I don't remember this blaster's shell as being held closed by solvent weld or catches - why is the "iFixit" pry-tool necessary?
Arasin Staubly - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 245
