Zum Hauptinhalt wechseln
Air Conditioning Capacitor Replacement
Was du brauchst
  1. Air Conditioning Capacitor Replacement, Diagnosis Step: Schritt 1, Bild 1 von 1
    • Turn on the A/C
    • If the unit turns on but does not spin, use a screwdriver to spin the fan blade.
    • If the blade spins freely, the capacitor is bad. If the blade does not spin freely, there is another issue, and a professional should be called.
  2. Air Conditioning Capacitor Replacement, Disconnect Power: Schritt 2, Bild 1 von 2 Air Conditioning Capacitor Replacement, Disconnect Power: Schritt 2, Bild 2 von 2
    • Turn off the power to the unit. This may mean flipping a switch or pulling a plug.
    • If the disconnect is not located next to the unit you will have to locate the breaker. You can make sure power is removed by trying to turn the unit on. If the unit does not turn on power has been removed and it is safe to work.
  3. Air Conditioning Capacitor Replacement, Door Removal: Schritt 3, Bild 1 von 2 Air Conditioning Capacitor Replacement, Door Removal: Schritt 3, Bild 2 von 2
    • Remove the door screws and door from the A/C.
    • It is only necessary to remove the bottom screws, but it is easier if the top screws are removed as well.
  4. Air Conditioning Capacitor Replacement, Discharging the Capacitor: Schritt 4, Bild 1 von 2 Air Conditioning Capacitor Replacement, Discharging the Capacitor: Schritt 4, Bild 2 von 2
    • Electric shock risk. Read the following bullets carefully before proceeding.
    • To displace energy stored in the capacitor, take a screwdriver and place the tip of the screwdriver against the wall
    • Tap the rod of the screwdriver against the metal connector that connects the wire and the capacitor
  5. Air Conditioning Capacitor Replacement, Wire Removal: Schritt 5, Bild 1 von 3 Air Conditioning Capacitor Replacement, Wire Removal: Schritt 5, Bild 2 von 3 Air Conditioning Capacitor Replacement, Wire Removal: Schritt 5, Bild 3 von 3
    • Before removing the wires, take a note of where each colored wire connects to.
    • Take a pair of needle nose pliers and place the tip around one of the wire connections to the capacitor.
    • Pull the wire upwards until the wire comes loose from the capacitor. It may help to use leverage against the capacitor.
    • Repeat for all 4 wires
  6. Air Conditioning Capacitor Replacement, Remove Bracket Screw and Capacitor: Schritt 6, Bild 1 von 2 Air Conditioning Capacitor Replacement, Remove Bracket Screw and Capacitor: Schritt 6, Bild 2 von 2
    • Unscrew the screw on the bracket holding the capacitor in place.
    • Remove the capacitor from the unit.
  7. Air Conditioning Capacitor Replacement, Find Matching Capacitor: Schritt 7, Bild 1 von 1
    • Find a new capacitor that matches the size of the old capacitor. (Ex: 45/5 or 70/10)
  8. Air Conditioning Capacitor Replacement, Screw Capacitor in Place: Schritt 8, Bild 1 von 2 Air Conditioning Capacitor Replacement, Screw Capacitor in Place: Schritt 8, Bild 2 von 2
    • Hold the capacitor in position with the bracket around it.
    • Screw in the screw holding the bracket in place. Make sure the capacitor is held tightly onto the A/C
  9. Air Conditioning Capacitor Replacement, Connect Wires to New Capacitor: Schritt 9, Bild 1 von 2 Air Conditioning Capacitor Replacement, Connect Wires to New Capacitor: Schritt 9, Bild 2 von 2
    • Reconnect the wires to the capacitor prongs in the same position they were located on the previous capacitor.
    • This can be done with pliers or by hand.
    • The most common setup is to have the brown wire on "FAN," the yellow wire on "HERM," and the red and purple wires on "C."
  10. Air Conditioning Capacitor Replacement, Screw Door Back On: Schritt 10, Bild 1 von 2 Air Conditioning Capacitor Replacement, Screw Door Back On: Schritt 10, Bild 2 von 2
    • Slide the door onto the A/C the way it originally was, and hold in place.
    • Screw in the door screws with drill or screwdriver.
  11. Air Conditioning Capacitor Replacement, Reconnect Power: Schritt 11, Bild 1 von 2 Air Conditioning Capacitor Replacement, Reconnect Power: Schritt 11, Bild 2 von 2
    • Turn on the Power by flipping the switch in the disconnect box to on, or pushing the pull plug back into place.
    • If the A/C is turned on, then the unit should turn on as usual.
Abschluss
Ryan Montgomery
193 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 71
Insgesamt: 3,941
