Einleitung
This guide will describe how to replace the motherboard in the controller.
Was du brauchst
Remove the screw on the battery lid. Using the Hex 4 socket and PH #0 bit, remove the 8 mm screw.
Using the Hex 4 socket and PH #0 bit, remove the four 8 mm screws on the panel.
Use the plastic opening tool to disconnect the front and back parts of the panel.
Using the PH #0 bit, remove two 8 mm screws on the main board.
De-solder the LED wires from the motherboard.
Lift the motherboard with a spudger to remove it from the case.
Eine weitere Person hat diese Anleitung absolviert.
