Einleitung
If the back case of your device is broken or keeps falling off and does not stay on, you will learn how to replace the backing in order to prevent any complications in the device.
Was du brauchst
Using your finger, pry open any of the four corners of the back case of your AirCard 770S, until you see the back case disconnect from the device.
Fast fertig!
Abschluss
