Einleitung
This guide is to show you how to replace the battery of your device by removing the old battery and replacing it with a new, working, battery. Make sure to charge your new battery (and therefore device) after inserting it into the device, as it may not have come with a full charge and appear broken.
Was du brauchst
Using your finger, pry open any of the four corners of the back of your AirCard 770S, until you see the back case disconnect from the device.
With the bottom of the device (above the charging port) facing you, use your thumb nail to lift up the battery.
Once the battery is lifted up, use the rest of your hand to remove the battery out from the device.
Eine weitere Person hat diese Anleitung absolviert.
