Zum Hauptinhalt wechseln
AirPods Charging Case Battery Replacement
Was du brauchst
Einführungsvideo
  1. AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: Schritt 1, Bild 1 von 2 AirPods Charging Case Battery Replacement, AirPods charging case battery replacement: Schritt 1, Bild 2 von 2
    • It is difficult to teardown the AirPods charging case because the charging case features 2 fixed points and the middle part is glued with adhesive. The charging case can easily be damaged by careless methods of dissasembly.
  2. AirPods Charging Case Battery Replacement, Creating a pry tool: Schritt 2, Bild 1 von 3 AirPods Charging Case Battery Replacement, Creating a pry tool: Schritt 2, Bild 2 von 3 AirPods Charging Case Battery Replacement, Creating a pry tool: Schritt 2, Bild 3 von 3
    • There is currently no special repair tool for the AirPods. Therefore, we need to make a set of disassembly tools.
    • Be careful when handling sharp and thin metal as it can easily injure your hands.
    • Make a pry piece with a 0.1mm steel plate. Firstly, cut the steel plate into the shape of a pry piece with a pair of scissors.
    • Grind the edges of the pry piece with a sheet of sandpaper.
  3. AirPods Charging Case Battery Replacement, Preparing the pry tool: Schritt 3, Bild 1 von 2 AirPods Charging Case Battery Replacement, Preparing the pry tool: Schritt 3, Bild 2 von 2
    • Bend the pry piece with a cutting nipper.
    • Use tweezers to make a shielding plate.
  4. AirPods Charging Case Battery Replacement, Prepare for opening the case: Schritt 4, Bild 1 von 3 AirPods Charging Case Battery Replacement, Prepare for opening the case: Schritt 4, Bild 2 von 3 AirPods Charging Case Battery Replacement, Prepare for opening the case: Schritt 4, Bild 3 von 3
    • To avoid damaging the charging case, wrap high-temperature tape around it.
    • Next, insert the pry piece into the seam of the two fixed points.
    • Use the pry knife to pry out a gap.
  5. AirPods Charging Case Battery Replacement, Start opening case: Schritt 5, Bild 1 von 2 AirPods Charging Case Battery Replacement, Start opening case: Schritt 5, Bild 2 von 2
    • Insert the shielding plate.
    • Insert the tweezers.
  6. AirPods Charging Case Battery Replacement, Removing the docking tubes: Schritt 6, Bild 1 von 2 AirPods Charging Case Battery Replacement, Removing the docking tubes: Schritt 6, Bild 2 von 2
    • Wedge the special pry piece into the seam to pull out the docking tubes.
    • Please do not damage the flex cable while pulling out.
  7. AirPods Charging Case Battery Replacement, Remove the old battery: Schritt 7, Bild 1 von 3 AirPods Charging Case Battery Replacement, Remove the old battery: Schritt 7, Bild 2 von 3 AirPods Charging Case Battery Replacement, Remove the old battery: Schritt 7, Bild 3 von 3
    • Attach the charging case to the holder and dip a small amount of alcohol on the battery.
    • Pry up the battery with the pry knife and the battery connector with tweezers.
    • Then take out the battery flex cable.
  8. AirPods Charging Case Battery Replacement, Test new battery: Schritt 8, Bild 1 von 3 AirPods Charging Case Battery Replacement, Test new battery: Schritt 8, Bild 2 von 3 AirPods Charging Case Battery Replacement, Test new battery: Schritt 8, Bild 3 von 3
    • Take out the battery.
    • Using a multimeter is not required to successfully replace the battery.
    • Measured by the multimeter, the battery is found to have no voltage.
    • Get a new battery that has a stable voltage of 3.6v-4.0v.
  9. AirPods Charging Case Battery Replacement, Put in new battery: Schritt 9, Bild 1 von 2 AirPods Charging Case Battery Replacement, Put in new battery: Schritt 9, Bild 2 von 2
    • Attach the double-sided tape to the new battery.
    • Put the new battery into the charging case and connect the battery flex cable.
  10. AirPods Charging Case Battery Replacement, Test charging: Schritt 10, Bild 1 von 2 AirPods Charging Case Battery Replacement, Test charging: Schritt 10, Bild 2 von 2
    • Plug in the charging cable. The case should now charge normally once more.
    • Put the earbuds in. The earbuds should charge normally too.
  11. AirPods Charging Case Battery Replacement, Attach new battery: Schritt 11, Bild 1 von 2 AirPods Charging Case Battery Replacement, Attach new battery: Schritt 11, Bild 2 von 2
    • Peel off the double-sided tape and attach the battery to the case.
    • Install the docking tubes.
  12. AirPods Charging Case Battery Replacement, Test functionality: Schritt 12, Bild 1 von 2 AirPods Charging Case Battery Replacement, Test functionality: Schritt 12, Bild 2 von 2
    • Connect the AirPods to the phone. Both the charging case and AirPods can now be charged and used normally again.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
REWA
11.654 Reputation
53 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 37
Letzten 7 Tage: 243
Letzten 30 Tage: 1,179
Insgesamt: 8,729
