Zum Hauptinhalt wechseln
Akai MPK25 Beat Pad Replacement
Was du brauchst
  1. Akai MPK25 Beat Pad Replacement, Face Plate: Schritt 1, Bild 1 von 1
    • Remove all the selector knob covers by pulling them off.
  2. Akai MPK25 Beat Pad Replacement: Schritt 2, Bild 1 von 1
    • Using needle nose pliers, remove the washers from the four corner selector knobs.
  3. Akai MPK25 Beat Pad Replacement: Schritt 3, Bild 1 von 1
    • Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
  4. Akai MPK25 Beat Pad Replacement: Schritt 4, Bild 1 von 3 Akai MPK25 Beat Pad Replacement: Schritt 4, Bild 2 von 3 Akai MPK25 Beat Pad Replacement: Schritt 4, Bild 3 von 3
    • Carefully flip the device to the front making sure you secure the face plate and the chassis together.
    • Please use care in following the step above to avoid ripping the ribbon cables connecting the two sides.
  5. Akai MPK25 Beat Pad Replacement: Schritt 5, Bild 1 von 3 Akai MPK25 Beat Pad Replacement: Schritt 5, Bild 2 von 3 Akai MPK25 Beat Pad Replacement: Schritt 5, Bild 3 von 3
    • Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
    • Use care when doing the step above so that the ribbon connectors which connect the top of the chassis to the top of the face plate are not damaged.
  6. Akai MPK25 Beat Pad Replacement, Beat Pad: Schritt 6, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the thirteen 9.8 mm silver screws holding the mother board to the face plate.
  7. Akai MPK25 Beat Pad Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the four 9.8mm screws holding in the base of the beat pad.
  8. Akai MPK25 Beat Pad Replacement: Schritt 8, Bild 1 von 2 Akai MPK25 Beat Pad Replacement: Schritt 8, Bild 2 von 2
    • Slightly lift the mother board near the edge of the beat pads and wiggle the beat pad ribbon connector free.
  9. Akai MPK25 Beat Pad Replacement: Schritt 9, Bild 1 von 2 Akai MPK25 Beat Pad Replacement: Schritt 9, Bild 2 von 2
    • Remove the beat pad sensor from the face plate.
Abschluss
Cal Poly, Team 20-6, Maness Winter 2013 Mitglied von Cal Poly, Team 20-6, Maness Winter 2013
CPSU-MANESS-W13S20G6
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 4,152
