Einleitung
This guide will help you remove the front panel of your Akaso EK7000. You will need a metal spudger or any other tool for prying and separating.
Was du brauchst
Locate the battery cover at the bottom of the camera. Use your fingers to gently pry open the battery cover.
Locate the small plastic flap attached to the battery. Pull the battery out towards you.
Using the metal spudger, gently pry open the front panel from the exposed battery cartridge.
Remove the rest of front panel with your fingers or with assistance from the spudger.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
