Zum Hauptinhalt wechseln
Akko MOD 007 v2 Keyboard Switch Replacement
Was du brauchst
  1. Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: Schritt 1, Bild 1 von 2 Akko MOD 007 v2 Keyboard Switch Replacement, Keyboard Switch: Schritt 1, Bild 2 von 2
    • Unplug the USB-C cable.
  2. Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 2, Bild 1 von 2 Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 2, Bild 2 von 2
    • Flip the keyboard over so the backside is facing up.
    • Remove the three longer 20.2 mm screws using the T5 Torx screwdriver.
    • Remove the three 8 mm screws using the T5 Torx screwdriver.
  3. Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 3, Bild 1 von 2 Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 3, Bild 2 von 2
    • Pull the front and back case apart.
    • If your keyboard is dirty, you’ll want to clean it before continuing. Use compressed air or a brush.
  4. Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 4, Bild 1 von 2 Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 4, Bild 2 von 2
    • Insert the keycap puller horizontally on the keycap and pull up.
    • Excessive force may break the tool or keycaps so don't yank the keycap up.
  5. Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 5, Bild 1 von 2 Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 5, Bild 2 von 2
    • Insert the switch puller vertically in the switch tabs and gently pull up.
  6. Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 6, Bild 1 von 3 Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 6, Bild 2 von 3 Akko MOD 007 v2 Keyboard Switch Replacement: Schritt 6, Bild 3 von 3
    • Orientate the new switch to align the pins to the board's sockets.
    • Push the switch down into the sockets.
    • Make sure the pins are aligned to sockets, as misalignment will cause the switch to be faulty.
Abschluss
Test the switch by opening a keyboard tester website, like 'keyboardtester.com,' and press the key to see if it activates.
Farhan
133 Reputation
1 Anleitung geschrieben
York University, Team A-2, Morris Fall 2022 Mitglied von York University, Team A-2, Morris Fall 2022
YORK-MORRIS-F22SAG2
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 63
Insgesamt: 1,023
