Zum Hauptinhalt wechseln
Einleitung
Alcatel Fierce 4 Camera is not working well? black spots? Might be the time for a replace. Don’t waste your money and let someone do it for you. You can do it using this guide
  1. Using a plastic opening tool, pry the back cover off of the phone.
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Remove the seventeen Phillips #000 screws from the mid-frame. Remove the seventeen Phillips #000 screws from the mid-frame.
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Use a plastic opening tool to disconnect all of the cables on the motherboard. Use a spudger to flip up the retaining flap on the  ribbon cable ZIF sockets.
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Remove the motherboard from the phone.
    • Remove the motherboard from the phone.
  6. Carefully pry up the battery with a plastic opening tool, or your hands.
    • Carefully pry up the battery with a plastic opening tool, or your hands.
  7. Remove the rubber piece surrounding the camera. Remove the rubber piece surrounding the camera.
    • Remove the rubber piece surrounding the camera.
  8. Use a plastic opening tool to pry up the camera. Use a plastic opening tool to pry up the camera.
    • Use a plastic opening tool to pry up the camera.
Abschluss
Rawan
638 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G2, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G2, Cagle Spring 2018
USFT-CAGLE-S18S1G2
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 116
