Einleitung
If you're noticing that Alcatel Fierce 4's earpiece is getting bad and you can’t hear well but you are not ready to upgrade your phone and you like it. It’s the time to replace the earpiece. Follow this guide from start to finish!
Was du brauchst
Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
Use a plastic opening tool to disconnect all of the cables on the motherboard.
Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
