Zum Hauptinhalt wechseln
Einleitung
If you're noticing that Alcatel Fierce 4's speaker is getting bad and low and you can’t hear well but you are not ready to upgrade your phone and you like it. It’s the time to replace the speaker. Follow this guide from start to finish!
  1. Using a plastic opening tool, pry the back cover off of the phone.
    • Using a plastic opening tool, pry the back cover off of the phone.
  2. Remove the seventeen Phillips #000 screws from the mid-frame. Remove the seventeen Phillips #000 screws from the mid-frame.
    • Remove the seventeen Phillips #000 screws from the mid-frame.
  3. Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
    • Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
  4. Use a plastic opening tool to disconnect all of the cables on the motherboard. Use a spudger to flip up the retaining flap on the  ribbon cable ZIF sockets.
    • Use a plastic opening tool to disconnect all of the cables on the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
  5. Remove the motherboard from the phone.
    • Remove the motherboard from the phone.
  6. Carefully pry up the battery with a plastic opening tool, or your hands.
    • Carefully pry up the battery with a plastic opening tool, or your hands.
  7. Use a plastic opening tool to pry up the speaker. Use a plastic opening tool to pry up the speaker. Use a plastic opening tool to pry up the speaker.
    • Use a plastic opening tool to pry up the speaker.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Rawan
638 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G2, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G2, Cagle Spring 2018
USFT-CAGLE-S18S1G2
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 153
