Einleitung
If you need to replace the antenna in your Alcatel IdealXCITE, you should use the following guide.
Was du brauchst
Place your finger in the small notch on the left corner of the phone.
Use your finger to gently pull up on the back cover where the notch is located.
Gently pull up on the back cover, working around the phone.
Remove the cover from the phone, and set it aside for later installation.
Place your thumb in the small notch between the battery and the phone.
Use your thumb to gently pry the battery up at the notch, releasing it from the phone.
Using a spudger, pry upwards in the indentation on the bottom right corner of the phone.
Work the tool gently around the antenna to release it.
