Zum Hauptinhalt wechseln
Alcatel One Touch Fierce Front Facing Camera Replacement
Was du brauchst
  1. Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 1 von 2 Alcatel One Touch Fierce Front Facing Camera Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: Schritt 2, Bild 1 von 3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: Schritt 2, Bild 2 von 3 Alcatel One Touch Fierce Front Facing Camera Replacement, Midframe: Schritt 2, Bild 3 von 3
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: Schritt 3, Bild 1 von 2 Alcatel One Touch Fierce Front Facing Camera Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
  4. Alcatel One Touch Fierce Front Facing Camera Replacement, Camera: Schritt 4, Bild 1 von 1
    • Carefully remove the motherboard from the rest of the phone.
  5. Alcatel One Touch Fierce Front Facing Camera Replacement: Schritt 5, Bild 1 von 2 Alcatel One Touch Fierce Front Facing Camera Replacement: Schritt 5, Bild 2 von 2
    • Use a pair of tweezers to disconnect and remove the front facing camera from the motherboard.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 5-5, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G5
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
tenx tenx tenx !!?
ismail - Antwort
I paid for a phone to capture precious moments, & the pictures are horrible, how can this be fixed??? This is wrong on all levels, I feel that we should be able to try any phone out before purchasing, so we know what we are buying, I'm returning my phone & wouldn't recommend this brand to anyone.
Jeanne Edenfield - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 6,456
