Zum Hauptinhalt wechseln
Alcatel One Touch Idol 3 Battery Replacement
Was du brauchst
  1. Alcatel One Touch Idol 3 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Alcatel One Touch Idol 3 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Alcatel One Touch Idol 3 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the sim tray by inserting a sim removal tool and then pulling it out.
  2. Alcatel One Touch Idol 3 Battery Replacement: Schritt 2, Bild 1 von 3 Alcatel One Touch Idol 3 Battery Replacement: Schritt 2, Bild 2 von 3 Alcatel One Touch Idol 3 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the back cover by moving around its perimeter with a thin object that can fit.
    • Eventually you will be able to pry open the back cover.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead.
  3. Alcatel One Touch Idol 3 Battery Replacement: Schritt 3, Bild 1 von 2 Alcatel One Touch Idol 3 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the protective sticker from the battery connection.
  4. Alcatel One Touch Idol 3 Battery Replacement: Schritt 4, Bild 1 von 2 Alcatel One Touch Idol 3 Battery Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery's connection to the motherboard by lifting it upwards.
  5. Alcatel One Touch Idol 3 Battery Replacement: Schritt 5, Bild 1 von 2 Alcatel One Touch Idol 3 Battery Replacement: Schritt 5, Bild 2 von 2
    • Add a small amount of isopropyl alcohol around the sides of the battery to soften the adhesive.
    • Take care to not get isopropyl alcohol on any other parts of the phone.
  6. Alcatel One Touch Idol 3 Battery Replacement: Schritt 6, Bild 1 von 3 Alcatel One Touch Idol 3 Battery Replacement: Schritt 6, Bild 2 von 3 Alcatel One Touch Idol 3 Battery Replacement: Schritt 6, Bild 3 von 3
    • Pry out the battery by leveraging an object under the battery and lifting it upwards.
    • Although a razor is depicted, we recommend using ESD-safe pry tools instead. A razor could easily puncture the battery and create a hazard.
Abschluss
Eric Lopez
133 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-87, Briggs Fall 2023 Mitglied von CSU Los Angeles, Team 2-87, Briggs Fall 2023
CSULA-BRIGGS-F23S2G87
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 98
