Einleitung
In the case that your device is unable to power on, their may be a problem with its battery. This guide will show you have to replace the battery for the Alcatel One Touch Pop 7.
Was du brauchst
Begin by opening SD port cover as this is the best location to start prying.
Use the plastic opening tool to pry around the edges of the back cover until it pops off.
Use precision tweezers to disconnect the battery from the ZIF connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
