Einleitung
This guide will walk you through the steps on changing your phones SD card with guided pictures to help at every stage
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
  1. Locate the small indent on the lower left corner. Use your fingers or a small plastic opening tool to lift the back cover off. Use your fingers or a small plastic opening tool to lift the back cover off.
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Locate the indent between the battery and your phone. Use your finger or a small plastic opening tool to lift the battery free. Use your finger or a small plastic opening tool to lift the battery free.
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Locate the SD card slot at the top left of the phone. If an SD card is not present, you can skip to step 4
    • Locate the SD card slot at the top left of the phone.
    • If an SD card is not present, you can skip to step 4
  5. The SD card will have an indent at the top, use this to carefully pull the card from the slot.
    • The SD card will have an indent at the top, use this to carefully pull the card from the slot.
  6. Grab the new SD card making sure not to touch the metallic area. With the metallic patch facing down, insert the card into the slot.
    • Grab the new SD card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jorge
159 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 82
