Zum Hauptinhalt wechseln
Alcatel OneTouch Elevate SIM Card Replacement
Was du brauchst
  1. Alcatel OneTouch Elevate SIM Card Replacement, Battery: Schritt 1, Bild 1 von 3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: Schritt 1, Bild 2 von 3 Alcatel OneTouch Elevate SIM Card Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate SIM Card Replacement: Schritt 2, Bild 1 von 3 Alcatel OneTouch Elevate SIM Card Replacement: Schritt 2, Bild 2 von 3 Alcatel OneTouch Elevate SIM Card Replacement: Schritt 2, Bild 3 von 3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate SIM Card Replacement, SIM card: Schritt 3, Bild 1 von 2 Alcatel OneTouch Elevate SIM Card Replacement, SIM card: Schritt 3, Bild 2 von 2
    • Locate the SIM card slot at the top left of the phone.
    • If an SIM card is not present, you can skip to step 4
  4. Alcatel OneTouch Elevate SIM Card Replacement: Schritt 4, Bild 1 von 1
    • The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
  5. Alcatel OneTouch Elevate SIM Card Replacement: Schritt 5, Bild 1 von 2 Alcatel OneTouch Elevate SIM Card Replacement: Schritt 5, Bild 2 von 2
    • Grab the new SIM card making sure not to touch the metallic area.
    • With the metallic patch facing down, insert the card into the slot.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jorge
165 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 24
Insgesamt: 477
