Zum Hauptinhalt wechseln
Alcatel OneTouch Elevate Screen Replacement
Was du brauchst
  1. Alcatel OneTouch Elevate Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Alcatel OneTouch Elevate Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Alcatel OneTouch Elevate Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel OneTouch Elevate Screen Replacement: Schritt 2, Bild 1 von 3 Alcatel OneTouch Elevate Screen Replacement: Schritt 2, Bild 2 von 3 Alcatel OneTouch Elevate Screen Replacement: Schritt 2, Bild 3 von 3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel OneTouch Elevate Screen Replacement, Screen: Schritt 3, Bild 1 von 2 Alcatel OneTouch Elevate Screen Replacement, Screen: Schritt 3, Bild 2 von 2
    • Remove back plate from phone.
    • Locate indent on corner of phone
    • Use pry tool to take off back of phone.
  4. Alcatel OneTouch Elevate Screen Replacement: Schritt 4, Bild 1 von 1
    • Find a very slim object to slide in between glass and phone.
    • Pry it off little by little until you are able to take it off.
  5. Alcatel OneTouch Elevate Screen Replacement: Schritt 5, Bild 1 von 1
    • After screen is off apply new screen
    • Make sure cable is in correct place after putting glass back on.
    • Test to make sure it works.
Abschluss
Jemier Virtue
97 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 188
