Zum Hauptinhalt wechseln
Alcatel OneTouch Evolve Camera Replacement
Was du brauchst
  1. Alcatel OneTouch Evolve Camera Replacement, Locate the access tab: Schritt 1, Bild 1 von 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
    Frag FixBot
    Kommentar hinzufügen
  2. Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 1 von 3 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 2 von 3 Alcatel OneTouch Evolve Camera Replacement, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 3 von 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
    Frag FixBot
  3. Alcatel OneTouch Evolve Camera Replacement, Identify the Battery: Schritt 3, Bild 1 von 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
    Frag FixBot
  4. Alcatel OneTouch Evolve Camera Replacement, Removing the battery: Schritt 4, Bild 1 von 2 Alcatel OneTouch Evolve Camera Replacement, Removing the battery: Schritt 4, Bild 2 von 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
    Frag FixBot
  5. Alcatel OneTouch Evolve Camera Replacement, Locate Screws Holding the Secondary Panel in Place: Schritt 5, Bild 1 von 1
    • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
    Frag FixBot
  6. Alcatel OneTouch Evolve Camera Replacement, Remove Screws: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Unscrew each screw, counter-clockwise (left), until each one has been removed.
    • If necessary, use tweezers to fully remove the screws from the device.
    • Remove battery before lifting off the panel.
    Frag FixBot
  7. Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: Schritt 7, Bild 1 von 3 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: Schritt 7, Bild 2 von 3 Alcatel OneTouch Evolve Camera Replacement, Prying the Panel Off: Schritt 7, Bild 3 von 3
    • Access the small pry tool in the tool kit
    • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
    • Rotate the pry tool 90 degrees until part of the panel lifts up
    • All areas need to be fully risen off before the panel can be removed.
    • Do not use the opening tool to pry open the device near the power button or near the volume button.
    Frag FixBot
  8. Alcatel OneTouch Evolve Camera Replacement, Locate the Camera on the Device: Schritt 8, Bild 1 von 1
    • See yellow square for the location of the camera on the mother board.
    Frag FixBot
  9. Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: Schritt 9, Bild 1 von 2 Alcatel OneTouch Evolve Camera Replacement, Unclip the connection to the motherboard.: Schritt 9, Bild 2 von 2
    • By gently lifting the bottom rectangular piece of the camera component upwards and away from the device, the connection will come free.
    • Remove the rubber casing from the camera, this piece is simply resting over the camera and can easily be removed.
    Frag FixBot
  10. Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: Schritt 10, Bild 1 von 2 Alcatel OneTouch Evolve Camera Replacement, Separate the camera from the glue patch: Schritt 10, Bild 2 von 2
    • Place your plastic opening tool underneath the bottom of the camera and rotate the tool to lift the camera. This will take a slight amount of force.
    • You will start to see the silver sticky patch between the camera and the mother board - leave this on the mother board.
    • Keep separating the camera from the sticky patch until completely removed.
    • To replace camera, use the yellow lines on the motherboard as your guide.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 4-5, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
Thank you kindly for your time to write the tutorial.
Tina Mccraney - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 41
Insgesamt: 2,014
