Zum Hauptinhalt wechseln
Alcatel OneTouch Evolve Volume Control Button Replacement
Was du brauchst
  1. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate the access tab: Schritt 1, Bild 1 von 1
    • This will be an opening with enough space to insert the flat head of the plastic opening tool.
    • It will be located on the bottom right of the phone
  2. Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 1 von 3 Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 2 von 3 Alcatel OneTouch Evolve Volume Control Button Replacement, Place the flat head end of the pry tool into the tab: Schritt 2, Bild 3 von 3
    • Rotate the pry tool 90 degrees until the panel lifts up.
    • With your thumb nail, lift the rest of the panel up around the perimeter of the phone.
  3. Alcatel OneTouch Evolve Volume Control Button Replacement, Identify the Battery: Schritt 3, Bild 1 von 1
    • This is the battery for the Alcatel One Touch Evolve. Look for this component when the back panel has been removed.
  4. Alcatel OneTouch Evolve Volume Control Button Replacement, Removing the battery: Schritt 4, Bild 1 von 2 Alcatel OneTouch Evolve Volume Control Button Replacement, Removing the battery: Schritt 4, Bild 2 von 2
    • Place finger in the tab on the top right corner of the battery indicated by a black arrow. With slight pressure, push battery down and out of the slot until the battery is removed
  5. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate Screws Holding the Secondary Panel in Place: Schritt 5, Bild 1 von 1
    • There will be eight 4.5mm screws that fit your Phillips head PH00 screwdriver notated by the red circles in the image.
  6. Alcatel OneTouch Evolve Volume Control Button Replacement, Remove Screws: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Unscrew each screw, counter-clockwise (left), until each one has been removed.
    • If necessary, use tweezers to fully remove the screws from the device.
    • Remove battery before lifting off the panel.
  7. Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: Schritt 7, Bild 1 von 3 Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: Schritt 7, Bild 2 von 3 Alcatel OneTouch Evolve Volume Control Button Replacement, Prying the Panel Off: Schritt 7, Bild 3 von 3
    • Access the small pry tool in the tool kit
    • Place flat head in the crease between the phone and panel where the matte finish meets the shiny finish of the front of the phone.
    • Rotate the pry tool 90 degrees until part of the panel lifts up
    • All areas need to be fully risen off before the panel can be removed.
    • Do not use the opening tool to pry open the device near the power button or near the volume button.
  8. Alcatel OneTouch Evolve Volume Control Button Replacement, Locate Volume Control Button: Schritt 8, Bild 1 von 1
    • This will be located in the top right of the back side of the secondary panel and will be clear in color.
  9. Alcatel OneTouch Evolve Volume Control Button Replacement, Remove Volume Control Button: Schritt 9, Bild 1 von 1
    • Using the smaller pry tool, place the flat head on the area of the button exposed to the exterior, and push with slight pressure until the button is inside the secondary panel.
    • Using the tweezers, lift the clear rubber extensions of the volume buttons out of their tabs located inside the secondary panel.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Brendan Egan
2.470 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 4-5, Miles Fall 2014 Mitglied von UMass Dartmouth, Team 4-5, Miles Fall 2014
UMASSD-MILES-F14S4G5
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 3,195
