Zum Hauptinhalt wechseln
Alcatel OneTouch Pop Icon Battery Replacement
Was du brauchst
  1. Alcatel OneTouch Pop Icon Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Battery Replacement: Schritt 2, Bild 1 von 2 Alcatel OneTouch Pop Icon Battery Replacement: Schritt 2, Bild 2 von 2
    • Use your thumbnail to lift the battery from the phone.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 2,391
