Zum Hauptinhalt wechseln
Alcatel OneTouch Pop Icon Headphone Jack Replacement
Was du brauchst
  1. Alcatel OneTouch Pop Icon Headphone Jack Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 2, Bild 1 von 2 Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Use your thumbnail to lift the battery from the phone.
  3. Alcatel OneTouch Pop Icon Headphone Jack Replacement, Interior Back Panel: Schritt 3, Bild 1 von 1
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
  4. Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
  5. Alcatel OneTouch Pop Icon Headphone Jack Replacement, Control Buttons: Schritt 5, Bild 1 von 1
    • Lift the latch and gently remove the ribbon from the latch.
  6. Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 6, Bild 1 von 2 Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 6, Bild 2 von 2
    • Use the metal spudger to gently pry the control buttons from the case.
    • The control buttons are glued to the case and are on a computer ribbon. When removing them it is best to move between them so as to avoid damaging them.
    • Make sure to use a plastic opening tool or nylon spudger before attempting to use a metal spudger. Metal spudgers can potentially damage your device.
  7. Alcatel OneTouch Pop Icon Headphone Jack Replacement, Motherboard: Schritt 7, Bild 1 von 3 Alcatel OneTouch Pop Icon Headphone Jack Replacement, Motherboard: Schritt 7, Bild 2 von 3 Alcatel OneTouch Pop Icon Headphone Jack Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Using tweezers, carefully detach the antenna from the motherboard.
  8. Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 8, Bild 1 von 3 Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 8, Bild 2 von 3 Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 8, Bild 3 von 3
    • Remove the tape on top of the ribbon.
    • Lift the black latch to release the ribbon.
    • Remove the ribbon from the latch.
  9. Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 9, Bild 1 von 1
    • Lift the tab from the casing.
  10. Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 10, Bild 1 von 3 Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 10, Bild 2 von 3 Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 10, Bild 3 von 3
    • Use the tweezers to remove tape the from the top of the latch. Still using the tweezers, lift the black latch to release the ribbon.
  11. Alcatel OneTouch Pop Icon Headphone Jack Replacement: Schritt 11, Bild 1 von 1
    • Remove the motherboard from the casing.
  12. Alcatel OneTouch Pop Icon Headphone Jack Replacement, Headphone Jack: Schritt 12, Bild 1 von 2 Alcatel OneTouch Pop Icon Headphone Jack Replacement, Headphone Jack: Schritt 12, Bild 2 von 2
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,128
