Zum Hauptinhalt wechseln
Einleitung
_______________ Video tutorial: _______________
Einführungsvideo
  1. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: Schritt 1, Bild 1 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: Schritt 1, Bild 2 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Cover Removal: Schritt 1, Bild 3 von 3
    • The Battery / Back cover is secured to the main frame by plastic clips.
    • Use a plastic tool to remove it.
  2. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: Schritt 2, Bild 1 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: Schritt 2, Bild 2 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 1: Schritt 2, Bild 3 von 3
    • Use a Phillips screwdriver and remove the two screws secured the battery connector shield.
    • With tweezers careful remove the battery connector shield.
  3. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Battery Disconnecting 2: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable.
  4. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: Schritt 4, Bild 1 von 2 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Main Board removal 1: Schritt 4, Bild 2 von 2
    • Disconnect:
    • Touchscreen flex cable
    • Main Camera flex cable
    • LCD flex cable
    • Vibra-motor
    • New line.Remove 7x Phillips screws.
  5. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 5, Bild 1 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 5, Bild 2 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 5, Bild 3 von 3
    • Careful unstuck the Volume buttons flex cable and the Power button flex cable.
    • Use a plastic tool and remove the Logic board.
  6. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: Schritt 6, Bild 1 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: Schritt 6, Bild 2 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement, Touch screen glass removal: Schritt 6, Bild 3 von 3
    • Use a hair dryer to warm the glass to soften the adhesive.
    • Use a knife or tool with a sharp edge and start the separating the glass from the frame.
    • Continue with a plastic tool.
  7. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 7, Bild 1 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 7, Bild 2 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 7, Bild 3 von 3
    • Insert wisdom here.
  8. Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 8, Bild 1 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 8, Bild 2 von 3 Alcatel POP C9 OT7047 Touch Screen Glass Digitizer Replacement: Schritt 8, Bild 3 von 3
    • Clean the frame and install a new adhesive tape.
    • Install the touch screen.
Abschluss
ZFix
186.406 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
308 Mitglieder
1.131 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 1,620
