Einleitung
USB charging ports can wear our or break off internally, which can prevent the device from charging. This guide is to show you how to take apart your phone and access the port for replacement.
Was du brauchst
Take off the case by flipping the phone over and wedging your finger in the notch on the bottom edge. Pry up until you hear the clicking and the edge releases. Continue to pry the case up, moving around the perimeter of the phone.
It should pop off in various places around the perimeter of the phone, and then come off easily.
Using a Phillips #000 screwdriver, remove the fourteen 3mm screws that connect the housing and the battery.
Remove the metal bracket covering the battery connector flex cable. Now that it's unscrewed, it should come out easily.
Disconnect the battery connector flex cable by sliding the black spudger under the wires and carefully prying up the entire terminal casing.
Starting at the top left corner and moving around the perimeter of the phone, insert the Jimmy between the housing and the phone and gently pry it up.
Remove the blue battery by lifting it straight up, or by gently turning the phone over into your palm and catching the battery as it comes out.
Turn the phone so the top is facing you. The board the USB charging port is attached to is on the bottom.
Disconnect the other side of the outer orange ribbon cable by locating the socket terminal at the base of the phone and prying it up using the blue spudger.
Disconnect the antenna flex cable by gently prying up the golden connection with the black spudger.
Slide the pointed end gently under the socket until it releases and hangs loose.
Carefully pry up the vibrator with the black spudger, being mindful of its connecting wires. Do not disconnect the vibrator from the board.
Using the black spudger, pry off the board the USB charging port is attached to.
Eine weitere Person hat diese Anleitung absolviert.
