Einleitung
If your battery life doesn't last like it used to then this guide will show you how to take out your Alcatel Pop 4 Plus Battery for replacement with out damaging phone. It a simple process of removing the outside cover, secondary cover, and then swapping out the battery for a new one.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
Use the flat end of the spudger disconnect the battery from the motherboard.
Use the flat end of the spudger tool to pry out the battery.
