Zum Hauptinhalt wechseln
Einleitung
If your front facing camera just isn't taking good pictures anymore then it might be time to replace it! This guide will show you how to replace your camera in just a few simple steps. You'll have to remove the the first and secondary covers to get to the motherboard. Then you'll have to disengage the connectors to the motherboard so that you can remove it and access the front camera.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Alcatel Pop 4 Plus Front Camera Replacement, Battery: Schritt 1, Bild 1 von 2 Alcatel Pop 4 Plus Front Camera Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
  2. Alcatel Pop 4 Plus Front Camera Replacement: Schritt 2, Bild 1 von 2 Alcatel Pop 4 Plus Front Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove seventeen 3mm Phillips #000 screws from the mid-frame.
  3. Alcatel Pop 4 Plus Front Camera Replacement: Schritt 3, Bild 1 von 1
    • Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
  4. Alcatel Pop 4 Plus Front Camera Replacement: Schritt 4, Bild 1 von 2 Alcatel Pop 4 Plus Front Camera Replacement: Schritt 4, Bild 2 von 2
    • Use the flat end of the spudger disconnect the battery from the motherboard.
    • Use the flat end of the spudger tool to pry out the battery.
  5. Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: Schritt 5, Bild 1 von 2 Alcatel Pop 4 Plus Front Camera Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
    • Slide the ribbon cable out of the socket.
  6. Alcatel Pop 4 Plus Front Camera Replacement: Schritt 6, Bild 1 von 2 Alcatel Pop 4 Plus Front Camera Replacement: Schritt 6, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the ribbon cable.
  7. Alcatel Pop 4 Plus Front Camera Replacement: Schritt 7, Bild 1 von 2 Alcatel Pop 4 Plus Front Camera Replacement: Schritt 7, Bild 2 von 2
    • Using the flat end of the spudger to disconnect the ribbon cable.
  8. Alcatel Pop 4 Plus Front Camera Replacement: Schritt 8, Bild 1 von 2 Alcatel Pop 4 Plus Front Camera Replacement: Schritt 8, Bild 2 von 2
    • Using the flat end of the spudger, disconnect the camera from the motherboard.
  9. Alcatel Pop 4 Plus Front Camera Replacement: Schritt 9, Bild 1 von 1
    • Use the flat end of the spudger to pry off the motherboard.
  10. Alcatel Pop 4 Plus Front Camera Replacement, Front Camera: Schritt 10, Bild 1 von 1
    • Disconnect the camera from the motherboard using the flattened of a spudger.
Abschluss
peter achanccaray
123 Reputation
1 Anleitung geschrieben
USF Tampa, Team S20-G6, Passmore Spring 2018 Mitglied von USF Tampa, Team S20-G6, Passmore Spring 2018
USFT-PASSMORE-S18S20G6
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 241
