Einleitung
This guide will help you locate where you SD card slot is on your Alcatel Pop 4 Plus and also show how to replace the SD card. All you need are your fingers to remove the outside cover and then slide the SD card in.
Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
