Einleitung
If the battery of your Alienware 15 R2 dies quickly, or fails to charge, you may consider replacing it. This will show you how to do so. When working with computers, always make sure to unplug your computer and ground yourself before reaching inner components so you don’t accidentally release an electrical charge into the sensitive technology. The discharge could potentially damage your computer’s internals.
Was du brauchst
Place laptop upside down with the hinge facing you, then remove the two 9mm Phillips #0 screws located in the bottom left and right of the of the rear panel.
Remove the rear panel by using the iFixit opening tool to separate it from the back of the laptop.
Use the iFixit opening tool to disconnect the battery cable. Put the iFixit tool underneath the cable and then pull it to remove.
Find the RAM located near the edge of the computer closest to you. Locate the small latches on either side of the RAM stick and push in the two latches to release. Gently grasp the RAM stick on either side and pull straight out. Repeat for the second RAM stick.
Using a Phillips #0 remove the small 1X 3mm screw behind where the RAM used to be.
Remove all screws from the back casing. (4X 18mm, 4X 10mm, 4X 6mm)
Press your finger in the hole next to the hard drive to lift the key board.
Using a Phillips #0 remove the screws holding the battery in. (3X 6mm)
You may also remove the ribbon cables on the bottom of the laptop to gain more room to work. (This is not required)
Remove the red, white, blue, and black colored wires connected to the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Honestly made an account to comment on this repair guide, this is extremely incomplete. I’d go as far as saying you’re likely to damage the product by relying solely on this guide, I would turn to a breakdown on YouTube instead. I’m not sure if this is listed under the correct product.
