Zum Hauptinhalt wechseln
Alienware 15 R3 Hard Drive Replacement
Was du brauchst
  1. Alienware 15 R3 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Alienware 15 R3 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Alienware 15 R3 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Find the Power option in the start menu and click Shut Down to turn off your Alienware 15 R3.
    • Wait a few seconds until all the computer's lights are off.
    • Unplug the power supply.
  2. Alienware 15 R3 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Alienware 15 R3 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Alienware 15 R3 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the six M2.5x13 screws from along the side edge of the base cover.
    • Loosen the top middle captive screw on the base cover.
    • It should not be removed, just loosen it so the bottom case can be removed.
    • Remove the base cover carefully.
    • Save these screws for later.
  3. Alienware 15 R3 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Alienware 15 R3 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Alienware 15 R3 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove the two M3x3 screws that are holding the bracket and the one M2.5x8 screw holding the hard drive assembly.
    • Remove the hard drive from the laptop.
  4. Alienware 15 R3 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Alienware 15 R3 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Prior to reassembly, clean the dust from the fans as circled in the picture if needed.
    • Put the bottom plate back on your laptop and secure it with the screws removed previously.
  5. Alienware 15 R3 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Your Alienware 15 R3 is ready to roll!
Abschluss
By removing the HDD, the Blue Screen of Death should not occur anymore when booting the laptop. Please note that the volume of storage on your computer may change.
2 weitere Personen haben diese Anleitung absolviert.
Yutong Yin
166 Reputation
1 Anleitung geschrieben
York University, Team S1-G1, O'Regan Fall 2021 Mitglied von York University, Team S1-G1, O'Regan Fall 2021
YORK-O'REGAN-F21S1G1
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 36
Insgesamt: 1,766
