Einleitung
One of the causes for a blank or pix-elated screen could because it is cracked. In this guide, we will show you how to replace your screen.
Was du brauchst
Put the laptop on a hard surface.
Make sure that the Alienware is not plugged into any power source.
First, we need to unplug the battery.
To unplug the battery, turn the computer upside down.
Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
Now, you are going to look for a yellow tag.
Unplug the black wire that has the yellow tag.
This with successfully disconnect your battery.
Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
Tilt the screen forward towards the keyboard.
Disconnect the plug that is connecting the screen to the main body.
