Zum Hauptinhalt wechseln
Alienware 17 R2 Screen Replacement
Was du brauchst
  1. Alienware 17 R2  Screen Replacement, Display: Schritt 1, Bild 1 von 1
    • Put the laptop on a hard surface.
    • Make sure that the Alienware is not plugged into any power source.
    • First, we need to unplug the battery.
  2. Alienware 17 R2  Screen Replacement: Schritt 2, Bild 1 von 2 Alienware 17 R2  Screen Replacement: Schritt 2, Bild 2 von 2
    • To unplug the battery, turn the computer upside down.
    • Remove the two 4mm screws from the plastic covering protecting the inner part of the laptop.
  3. Alienware 17 R2  Screen Replacement: Schritt 3, Bild 1 von 2 Alienware 17 R2  Screen Replacement: Schritt 3, Bild 2 von 2
    • Gently, pull the cover up and slide it off.
  4. Alienware 17 R2  Screen Replacement: Schritt 4, Bild 1 von 3 Alienware 17 R2  Screen Replacement: Schritt 4, Bild 2 von 3 Alienware 17 R2  Screen Replacement: Schritt 4, Bild 3 von 3
    • Now, you are going to look for a yellow tag.
    • Unplug the black wire that has the yellow tag.
    • This with successfully disconnect your battery.
  5. Alienware 17 R2  Screen Replacement: Schritt 5, Bild 1 von 2 Alienware 17 R2  Screen Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, gently remove the black plastic casing from the LCD screen.
    • Run the opening tool along the inner side of the computer where the screen and the plastic covering meet.
  6. Alienware 17 R2  Screen Replacement: Schritt 6, Bild 1 von 1
    • No you will unscrew the 2mm screws on the top and bottom side of the screen.
  7. Alienware 17 R2  Screen Replacement: Schritt 7, Bild 1 von 1
    • Tilt the screen forward towards the keyboard.
    • Disconnect the plug that is connecting the screen to the main body.
  8. Alienware 17 R2  Screen Replacement: Schritt 8, Bild 1 von 1
    • Gently, lift the display away from the laptop.
Abschluss
Luis Garcia
402 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 3,192
