Zum Hauptinhalt wechseln
Alienware 17 R2 Hard Drive Replacement
Was du brauchst
  1. Alienware 17 R2 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Make sure the laptop is unplugged from any power source.
    • Put the laptop facing down on a hard surface.
  2. Alienware 17 R2 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Alienware 17 R2 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Alienware 17 R2 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the two 6mm screws on the bottom side of the laptop.
    • Lift up the back cover and slide towards you.
  3. Alienware 17 R2 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Alienware 17 R2 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Locate the Hard Drive
  4. Alienware 17 R2 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the screws that connect the SSD Bay to the laptop
  5. Alienware 17 R2 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the three screws holding the hard drive
  6. Alienware 17 R2 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Alienware 17 R2 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the four screws on the long sides of the hard drive casing
  7. Alienware 17 R2 Hard Drive Replacement: Schritt 7, Bild 1 von 3 Alienware 17 R2 Hard Drive Replacement: Schritt 7, Bild 2 von 3 Alienware 17 R2 Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
    • Your hard drive has now been successfully removed from your device
Abschluss
Luis Garcia
402 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 1,626
