Einleitung
This guide will show you how to replace the Hard Drive for your Alienware 17 R3 laptop. Ensure you have all the necessary tools before starting.
Was du brauchst
Turn the computer off.
Disconnect the charging cable from the computer.
Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
7 weitere Personen haben diese Anleitung absolviert.
