Einleitung
This guide will show you how to replace the RAM for your Alienware 17 R3 laptop. Ensure you have all the necessary tools before starting.
Was du brauchst
Unplug the black wire with the yellow tag to disconnect the battery from the RAM stick.
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
After the RAM chip has popped up, pull it straight out of its socket.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
