Zum Hauptinhalt wechseln
Alienware 17 R4 Solid State Drive (SSD) Replacement
Was du brauchst
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 2, Bild 1 von 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 2, Bild 2 von 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): Schritt 3, Bild 1 von 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): Schritt 3, Bild 2 von 3 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): Schritt 3, Bild 3 von 3
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 4, Bild 1 von 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 4, Bild 2 von 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 4, Bild 3 von 3
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 5, Bild 1 von 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 5, Bild 2 von 3 Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 5, Bild 3 von 3
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 6, Bild 1 von 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 6, Bild 2 von 2
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: Schritt 7, Bild 1 von 2 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: Schritt 7, Bild 2 von 2
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 8, Bild 1 von 2 Alienware 17 R4 Solid State Drive (SSD) Replacement: Schritt 8, Bild 2 von 2
    • Slide the solid state drive towards yourself to prevent damage to the card.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Mitglied von CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Mitglieder
9 Anleitungen geschrieben
1 Kommentar zur Anleitung
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 38
Insgesamt: 7,473
