Zum Hauptinhalt wechseln
Alienware 17 R4 Wi-Fi Card Replacement
Was du brauchst
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Alienware 17 R4 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: Schritt 3, Bild 1 von 1
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Alienware 17 R4 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Alienware 17 R4 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Alienware 17 R4 Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 2 Alienware 17 R4 Wi-Fi Card Replacement: Schritt 6, Bild 2 von 2
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Fullerton, Team S2-G4, Bruce Fall 2017 Mitglied von CSU Fullerton, Team S2-G4, Bruce Fall 2017
CSUF-BRUCE-F17S2G4
4 Mitglieder
9 Anleitungen geschrieben
1 Kommentar zur Anleitung
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 49
Insgesamt: 5,691
